S2000 Motor converted to FWD?
Old 05-09-2007, 10:40 PM
Oregonized's Avatar
Default S2000 Motor converted to FWD?
Why hasn't it been done? You could flip the motor to sit sideways just like a K20 and then get an adapter plate to bolt on a K series trans or B series trans....Just wanted to know why nobody has tried yet. If you did flip it sideways it would sit with the exhaust man in the front and the intake manifold in the back and the pulleys would sit in the same area as a B series motor.
Old 05-09-2007, 10:47 PM
Oregonized's Avatar
Default Re: S2000 Motor converted to FWD? (Oregonized)
http://austin.craigslist.org/pts/323849056.html Oh and these pics of the S2000 motor sitting there inspired my insanity. I know its been asked before prbly but I wonder if anyone on here has thoroughly looked over what would need to be done. I can see you would need to weld some motor mount bracket spots onto the side of the block....I dont know if that would be safe or even possible. If you could find a way to mount this thing and bolt a FWD transmission to it then I see it being possible.
Old 05-10-2007, 12:45 AM
Infinityzer050's Avatar
Old 05-10-2007, 03:33 AM
flatfourfan's Avatar
Default Re: S2000 Motor converted to FWD? (Infinityzer050)
^^^that's probably the worst photochop ever.....................I think the main reason that it's not been done ( I may be mistaken) is cost, fine you get the engine for $800, add to that two tonnes of other **** and next thing you know, you're in K territory..........
[edit by moderator: post is in correct, see http://www.prototyperacing.com/f20kit.htm]
Old 05-10-2007, 06:14 AM
MoonScryer's Avatar
That is not a photochop; that was done as a test by a shop that posted that pic in a thread on this forum. No, I don't remember who, but it was some time ago.
The only two bolt holes that line up are the top ones, and that is it.
Old 05-10-2007, 09:18 AM
Oregonized's Avatar
Default Re: (MoonScryer)
I know you would be in K territory and you see plenty of K swaps these days. If someone could make an adapter plate for the block to run a FWD trans I could see this motor going into lots of cars.
Old 05-10-2007, 12:40 PM
sauceja's Avatar
Default Re: (Oregonized)
So you want a 2.0 liter? Why not just get a F20B or an H22A and use a B tranny.
For the money you just saved upgrade everything.
Or just get a K swap.
Price would be ridiculous plus I read something on that motor not spinning the same direction and you would have 5 reverse gears and 1 forward. But I do not know how much truth to that.
I just know I read it in one of the bigger threads discussing this.
Old 05-10-2007, 05:55 PM
hondastreet's Avatar
This idea are not so stupid !!!
Why not ? I think this setup can be fun !!!
$$$ If you don't have cash, sorry for you
Old 05-10-2007, 10:10 PM
fltblkcrx's Avatar
Default Re: S2000 Motor converted to FWD? (hondastreet)
first of all by getting an f20b, or h22a you would need the pertaining transmission off of an "h" of "f" series, no b-series is compatible. it would also depend on what car you would be putting it into. this would matter for a reason that has already been said, "cost". putting into a b-series car would be an absolute nightmare. putting it into an accord or prelude, would still be quite the headache. either way you would be able to build, or boost an h/f-series for the price of everything put together. if you wanted to spend money like that and make a unique honda, make a rwd something....that would be coo
Old 05-11-2007, 07:36 AM
MoonScryer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">first of all by getting an f20b, or h22a you would need the pertaining transmission off of an "h" of "f" series, no b-series is compatible. it would also depend on what car you would be putting it into. this would matter for a reason that has already been said, "cost". putting into a b-series car would be an absolute nightmare. putting it into an accord or prelude, would still be quite the headache. either way you would be able to build, or boost an h/f-series for the price of everything put together. if you wanted to spend money like that and make a unique honda, make a rwd something....that would be coo </TD></TR></TABLE>
For one who has done so many swaps, you sure don't know what is going on in the hybrid swap world as of late.
H2B ring a bell? Hell, people have put D series on F and H, even B on an A series (old 80's accord).
As to how to do it in a nightmare of a chasis - its called a K swap.
Old 05-11-2007, 09:37 AM
sauceja's Avatar
Amen. Look at Bense. He is putting a D-series tranny on an F20B (jdm accord motor)
There is 155 pages of H2B (h22a mated with a B-series tranny)
What I said ^ about reading is the F20C S2000 motors have been said to spin a completely different direction than the B-series tranny can go.
Being 5 revers and 1 forward gear. Unless your tow-mater and can drive fast backwards, not fun.
And for the record. H-series transmissions suck.
Old 05-11-2007, 10:08 AM
Oregonized's Avatar
Default Re: (sauceja)
http://www.prototyperacing.com/f20kit.htm Check this link out....Someone is already in the process of making an adapter plate to mate a K series trans to an F20C motor! This is where that picture comes from.
Old 05-12-2007, 02:47 PM
int3gr4vtec's Avatar
S2000 FWD in a civic
Old 05-12-2007, 07:09 PM
SubTitle's Avatar
Default Re: (int3gr4vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by int3gr4vtec &raquo;</TD></TR><TR><TD CLASS="quote">img]http://i77.photobucket.com/albums/j43/int3gr4vtec/s2kblok3nc4.jpg[/img]
S2000 FWD in a civic </TD></TR></TABLE>
any more pics
Old 05-13-2007, 09:47 AM
Ditto
RotiEatter's Avatar
Why do people still ask this question? This thread should be locked and deleted.
Old 05-13-2007, 09:48 AM
Ditto
RotiEatter's Avatar
Default Re: (RotiEatter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RotiEatter &raquo;</TD></TR><TR><TD CLASS="quote">Why do people still ask this question? This thread should be locked and deleted.</TD></TR></TABLE>
I agree with myself ....
» Post reported
The post was successfully reported to the moderator. Click here to return to the topic.
Old 05-13-2007, 01:20 PM
Go Tigers!
Bense's Avatar
sorry bro, this thread shouldn't be locked. I was actually JUST thinking about this thing earlier, lemme upload my pics....
Don't ask me anything about it, all i know is from what I see in these pics. Look how they fabbed the header OVER the crossmember and modified the firewall. Pretty slick if you ask me.
This might be my next project
Old 05-13-2007, 09:56 PM
88ED8's Avatar
Default Re: (Bense)
^ I've also thought about this swap, but in a CRX of corse
Old 05-13-2007, 10:06 PM
Oregonized's Avatar
Default Re: (88ED8)
Who wants to build an adapter plate to bolt up a K-Series trans and get some mount measurements???
Old 05-14-2007, 12:12 PM
QuarterMileMaster's Avatar
I don't get it. Why not just do a k20a (Type R)? Aren't the performance specs pretty much the same?
Old 05-14-2007, 12:39 PM
88ED8's Avatar
Default Re: (QuarterMileMaster)
the reason people do/are interested in swaps that may seem to make no sense at all (as compared to a easier route) is that it's different + the challenge of doing it!!!! Well at least that's why I am interested in things like this... Imagine a F20c/k20 6spd or a h2b (H22A/ITR), or a H22A/CRV AWD 5spd (all swaps mentioned have to be done in a CRX ), or even a H2D in a Civic wagon AWD... It's all about the W W factor, plus I like to amuse myself
Old 05-14-2007, 01:00 PM
Default Re: (88ED8)
Yeah, I totally get the wow factor no doubt. But this one doesn't wow me, all previously mentioned ones do though.
I'd build an AWD EF of some sort in a heart beat if there was some way the drivetrain would hold the power. But that's off topic.
Cool idea I guess...
Old 05-15-2007, 04:58 AM
Go Tigers!
Bense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by QuarterMileMaster &raquo;</TD></TR><TR><TD CLASS="quote">I don't get it. Why not just do a k20a (Type R)? Aren't the performance specs pretty much the same?</TD></TR></TABLE>
Ever seen a DC5 ITR in the states, I haven't.
F20Cs are a lot more abundant than JDM ITR K20R engines. Not to mention that....oh yeah:
http://www.k20a.org/forum/showthread.php?t=17881
As time progresses we're gonna have more ep3 trannys laying around. Same with accord 5mt trans. We can make use of them.
It won't be as easy of a swap as a straight up K swap. That hybrid trans can be built for a reasonable price too. Make use of what we have available.
Most people won't think that my F2D swap with a F20B is very impressive, but when I'm running times equivalent to an all motor K swapped EG, with less money invested than an b18c5 swap, then i suspect that it will get more attention.
F2K wouldn't be the dream swap, but it serves it's purpose
Old 05-15-2007, 09:09 AM
Dueceification's Avatar
Default Re: (Bense)
I agree whats so bad about a F2k? Having a bone stock 240hp engine in your integra or civic wouldn't be a so bad
Old 05-15-2007, 10:18 AM
Go Tigers!
Bense's Avatar
exactly. the F20C and F22C = badass.
Quick Reply: S2000 Motor converted to FWD?
