JDM B16a CRX... Partial Throttle problems..
Old Apr 16, 2007 | 09:05 AM
pac_crx's Avatar
Default JDM B16a CRX... Partial Throttle problems..
Ok,
So I got the motor in the car, and it bump starts clean, and Idles. It is surging a little bit between 300-900 RPMs, and that may be the FITV/IACV. However the real problem is that under load I cannot use more than 1/4 throttle without inducing backfire, and hesitation. Could the IACV/FITV cause that as well?
Let me know if you have had a similar problem/Resolution.
I have NO CELs.
If I stay under 1/4 throttle I can drive the car normally.
If the car is not in gear, I can use more than 1/4 throttle, but not WOT.
Thanks,
Old Apr 16, 2007 | 11:58 AM
Slurp56's Avatar
Default Re: JDM B16a CRX... Partial Throttle problems.. (pac_crx)
I've seen similar problems when the O2 sensor are reveresed, but it normally cleans up after about 4,500 RPM.
Remove the intake and start the car. Look in the throttlebody, there should be 2 holes. 1 should be the air bypass port for the IAC adn the other for the FITV. Use your finger and plug 1 at a time. If it stops surging, then follow the path to the problem. also, look for a vacuum leak.
eg5b16
Jun 10, 2011 06:36 PM
Spectrum24x
Mar 1, 2006 04:15 AM
TheHatchHog
Apr 23, 2004 03:08 PM
InfamousRS
Jul 4, 2003 01:20 PM
Don
Apr 29, 2001 08:43 PM
