H2b swap and high idle someone please help me figure out whats up
I have a h22 in a 95 integra rs with a euro r manifold and throttle body. I cant get my car to idle under 2100. Ive checked for vac leaks about 10 times and sprayed down the intake manifold area numerous times with carb cleaner and i cant find nothing. I have adjusted the throttle cable and the screw under the throttle pulley and still nothing. The tps sensor wasnt on the t-body when i got it but i changed it and set it on 0.5v and 4.5v wide open throttle. Only thing ive noticed is that when i unplug the map sensor it idles like normal. Ive used 4 different ecu's so i know it's not that as well. I still have the euro r IACV but it's not pluged up ive got the usdm one pluged up and sitting under the manifold. Im not throwing any CEL'S at all.
Re: (alphajesse)
if you take the take the intake manifold off you will see little tiny holes by the ports get it welded or pluged i had that same problem or spray some carb cleaner around the intake manifold and locate the leak . the car will almost wants to die out if theres a leak.
jordan_civic
05-26-2008 09:39 PM
mikeunreal
10-26-2005 05:31 PM
