h2b.does it still affect handling?
Old Apr 17, 2007 | 02:51 PM
burnoutdoc's Avatar
Default h2b.does it still affect handling?
onwe downside of the prelude swap was the weight it put on the front end.for drag racing it wasnt a big deal,but roadracing made it a less desirable swap.does a b trans,save enuff weight to make it better to roadracers?
Old Apr 17, 2007 | 03:34 PM
turtleman321's Avatar
no the b series trans is like 1 pounds lighter but with the plate and spacer for the flywheel they are probaly the same
Old Apr 17, 2007 | 03:57 PM
wantalude's Avatar
im no authority on the H2B swap, but ive read a few posts from some autocross guys that said its not that much of a difference. youre only talking about 35 pounds or so. you could alleviate that with a battery relocation and some light weight wheels.
Old Apr 17, 2007 | 05:45 PM
2point2's Avatar
Default Re: (wantalude)
the weight difference between a d-series swap and a b-series swap is quite a bit.
the weight difference between an b-series swap and an h-series swap is negligible.
forget what you've heard or read in the past.
Old Apr 17, 2007 | 06:06 PM
SIXTY's Avatar
Default Re: (2point2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point2 &raquo;</TD></TR><TR><TD CLASS="quote">the weight difference between a d-series swap and a b-series swap is quite a bit.
forget what you've heard or read in the past. </TD></TR></TABLE>
amen
Old Apr 17, 2007 | 08:38 PM
high_revs's Avatar
x2....
Old Apr 19, 2007 | 02:11 PM
burnoutdoc's Avatar
Default Re: (h2b_eg8)
i kinda figured it wouldnt matter.i have a 93 4 dr and dont like the way it understeers already.
Old Apr 19, 2007 | 04:59 PM
high_revs's Avatar
my 93 4dr is fine with this swap...i love taking turns
Old Apr 20, 2007 | 04:09 PM
burnoutdoc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h2b_eg8 &raquo;</TD></TR><TR><TD CLASS="quote">my 93 4dr is fine with this swap...i love taking turns </TD></TR></TABLE>
what kinda suspension you got?
Old Apr 21, 2007 | 10:20 AM
Syndacate's Avatar
I'm no expert, but the transmission is not what makes the H ~150lbs more than the B or D.
Old Apr 22, 2007 | 06:54 AM
2point2's Avatar
Default Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">I'm no expert, but the transmission is not what makes the H ~150lbs more than the B or D.</TD></TR></TABLE>
what?
Old Apr 22, 2007 | 06:00 PM
gibsanez's Avatar
We already figured out it was not the transmission, as said here
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turtleman321 &raquo;</TD></TR><TR><TD CLASS="quote">no the b series trans is like 1 pounds lighter but with the plate and spacer for the flywheel they are probaly the same</TD></TR></TABLE>
and from the guy who actually did the swap...
so why does the H weigh 150 more than the B?
Old Apr 22, 2007 | 06:25 PM
it doesnt weigh 150 pounds more. its more like 45
Old Apr 22, 2007 | 06:43 PM
2point2's Avatar
Default Re: (turtleman321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turtleman321 &raquo;</TD></TR><TR><TD CLASS="quote">it doesnt weigh 150 pounds more. its more like 45</TD></TR></TABLE>
and
I have yet to confirm but people in the allmotor threads have claimed that the balance shaft components (that are often discarded in H22A performance applications) weight over 20lbs.
The weight myth will never die..
Old Apr 23, 2007 | 03:49 PM
burnoutdoc's Avatar
i guess i should rephrase my question.for roadracing purposes,which would handle better, a itr motor setup or an h2b swap.both in same eg chassis.
Old Apr 24, 2007 | 06:02 AM
high_revs's Avatar
wont really matter with good suspension....plus you'll have a much better powere band over the itr swap
Porsche944Turbo
Honda Civic (2001 - 2005)
Aug 7, 2016 08:51 PM
KidRuthless
Apr 2, 2014 11:29 AM
Black R
23
Mar 14, 2012 10:03 AM
4RODO
Oct 25, 2007 09:09 AM
JDMlyfestyle
Feb 14, 2005 10:03 PM
