second o2 sensor
Old Apr 24, 2007 | 09:29 AM
994door's Avatar
Default second o2 sensor
I'm swapping a 96 gsr into my 99 civic. I'm keeping it obd2 so it requires a second o2 sensor. on the stock motor the catalytic converter is attached to the manifold so there isnt one under the car. do i need to put a catalytic converter under the car for the new motor?
Old Apr 24, 2007 | 03:43 PM
Slurp56's Avatar
Default Re: second o2 sensor (994door)
Yup.
Old Apr 24, 2007 | 03:44 PM
B18CivicEJ8's Avatar
You will need the cat back exhaust section of a 99 Civic EX for it to work. I would also recommend you get a 99 Civic EX engine harness. This will save you a few hours because you only have to add in 1 wire for the Intake Air Bypass valve.
Old Apr 24, 2007 | 04:29 PM
994door's Avatar
Default Re: second o2 sensor (B18CivicEJ8)
thanks... does it matter what car the cat is for because i have a new cat for my 91 integra but i sold the car before i could install it? so i need get a catback for a 4 door ex the attach the cat to that?
Modified by 994door at 9:53 PM 4/24/2007
Old Apr 25, 2007 | 10:21 AM
Yes, you need a cat from a 99 Civic EX because that already has the secondary O2 sensor bung tapped into the cat. The 91 integra cat will not have this sensor which will defeat the purpose of your original question. So you need the cat and entire exhaust section of a 99 Civic EX, unless you plan on adding an aftermarket cat-back exhaust. If you go that route, then all you need is the cat from the 99 EX.
Old Apr 30, 2007 | 02:57 PM
994door's Avatar
does the jdm gsr ecu require a second o2 sensor?
stacdizzle
Honda Civic (2001 - 2005)
Dec 4, 2013 10:14 AM
thead
Oct 25, 2010 02:52 PM
92eghb
12
Feb 27, 2009 08:32 AM
"Hites"
Feb 11, 2005 05:24 PM
typesguy
Feb 25, 2004 08:14 PM
