H22a Transmission
H22a Transmission
When i bought my accord it already had the h22a with a LSD transmission in it and 5th gear would grind almost every time. So i did a little research and found a posting about synchromesh and I put that in about 2 months ago and my grind is gone.
Now for some reason lately it is very hard to get the tranmission in gear and i cant shift fast or the transmission will not let it go in gear. In order for me to get the car into first I have to put a good amount of force on the shifter. I tried to go into sencond then back into first but that did not help either. Second is just as difficult to get into.
I was thinking about changing the fluid maybe with the summer heat coming in this fluid can't hold up.
Any help would be greatly appreciated.
Re: H22a Transmission (flatline911)
Sounds like u're losing pressure on ur clutch, u probly have a leak in ur clutch master cylinder or slave cylinder. Check ur clutch fluid reservoir and make sure u have plenty of clutch fluid in there. It probly would also help to bleed the clutch.
