kswap in a ek hatch im doing for a buddy
this is a budget swap. he got a rsx full swap for $1500cdn from the junk yard and he even cut out the rsx mounts from the car. pics will be added
2002 rsx type-s motor trans ecu with 107392 km
first i removed the sad d16y7 and cut out all the old mounts. cleaned the engine bay and painted champ white. the car will be getting sprayed after the swap.
i used a fuel rail from a 99 accord f23 sohc vtec and the hondata wiring.
i cut the exhaust mani off at the flange and angled it down about 10 degrees for clearance and i also installed an eg rear subframe with rack.
all thats is connect the fuel lines and axles and shift linkage and finish the custom 3" exhaust
for the fuel rail the accord one is spaced out perfectly for the injectors. i had to mill out the injectors ports as the rsx injectors were larger. after drilling new holes to line up with the k20 IM and using appropriate bolts and spacers it work mint.$250 saved woo woo.
the car will be going turbo later on this summer. OMG there is soooooo much room
ERIC1
66
12-02-2009 01:14 PM
