D16z6 into D15b v-tec E
Old May 1, 2007 | 10:14 AM
seductive's Avatar
Default D16z6 into D15b v-tec E
Hi guys iv just fitted a d16z6 into my vei. i left the vei loom in and the car started up stright away but were having a few problems with the ecu light not going out and there are a few connections that dont go anywere.
I'v lost my camer so i cant take any pic's but i hope you can help me from the info i'v given you
Old May 1, 2007 | 02:52 PM
Slurp56's Avatar
Default Re: D16z6 into D15b v-tec E (seductive)
If the light stays lit, it means you have a Check Engine Light. Do a search on here or check over at c-speedracing.com for a howto on determining your check engine light code. It is trying to tell you what is wrong
Edit: also the D16 used a 4 wire O2 sensor while the D15b used a 7 wire? If you are running the P28 ECU you'll need to switch the O2 sensor.
Old May 3, 2007 | 11:15 AM
seductive's Avatar
Default Re: D16z6 into D15b v-tec E (Slurp56)
thanks dude i'll try that
Jakessw
Apr 25, 2010 06:06 PM
safiy
Mar 18, 2007 07:39 PM
[Eg.6]LiLbOy916
Oct 24, 2006 04:38 PM
racing27
Jun 28, 2006 10:57 AM
crazydude75927
Jan 11, 2003 11:33 AM
