93 ls motor into 93 CX
Old 04-16-2007, 06:27 PM
enasnitsi's Avatar
Default 93 ls motor into 93 CX
I have a 93 CX that is stock right now but I recently just got a 93 ls integra for $50. It was hit in the back. I plan to swap the brakes to the CX. It has rear disc and the fronts are bigger than the CX's stock brakes. I am also wondering what I will need to get the engine and trans into my car. Can I use the harness and computer from the ls? Or use mine? Any help would be great. Thanks
Old 04-17-2007, 09:43 PM
D16Z6racing's Avatar
Default Re: 93 ls motor into 93 CX (enasnitsi)
Motor swap is pretty straight forward, except the tranny. the LS is cable. you need a 94+ tranny to get hydro, unless you get the conversion kit. Use the LS ECU. It's still OBD1.
I know 90-93 tegs are a straight swap on brakes to a 88-91 civic, but not sure on 92+ civics. I'd think the rear would at least work. Be careful though if it was hit in the rear, the smallest bend could be trouble.
Old 04-18-2007, 11:54 AM
enasnitsi's Avatar
Default Re: 93 ls motor into 93 CX (D16Z6racing)
thanks for the info. thats what I was thinking. I am going to check everything over once I get it out of the car. I have a lsd B16 tranny I will use for it. If anyone has any more info. on the brakes that would be great. Still wondering if they will bolt into it or not.
Thanks
swing lo
03-29-2005 06:22 PM
LShatchie
07-25-2004 12:24 AM
Andres-eh2
05-04-2003 05:34 PM
Quick Reply: 93 ls motor into 93 CX
