I wnat to do h23 vtec!!!
i have siezed h22a4.
removed the head.
found someone who give me a short block h23 for 150-200/
i need like a real walkthough. not that list of parts bull.
also how reliable is this setup/
i been searchin!!
btw this is going into my eg civic hatch wich has an h22a1. which started trippin the knock sensor everytime i drive!!!!
removed the head.
i been searchin!!
Re: I wnat to do h23 vtec!!! (djsire)
any setup can be reliable if built right. from what ive read its not that great of a swap though, the bottom end of the H23 wasnt made to spin to 7000+ rpms, it doesnt have the oil squirters like the H22... why not just rebuild your motor or get another H22 shortblock? i think you need to use that old search button
h23vtec is the way to go, you'll love the power, just dont rev it higher then needed and you'll be fine....everything needs to be vtec and you can take that all from your old longblock...
Re: (h2b_eg8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h2b_eg8 »</TD></TR><TR><TD CLASS="quote">everything needs to be vtec and you can take that all from your old longblock...</TD></TR></TABLE>
this basically tell me NOhing!
Re: I wnat to do h23 vtec!!! (wantalude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantalude »</TD></TR><TR><TD CLASS="quote">any setup can be reliable if built right. from what ive read its not that great of a swap though, the bottom end of the H23 wasnt made to spin to 7000+ rpms, it doesnt have the oil squirters like the H22... why not just rebuild your motor or get another H22 shortblock? i think you need to use that old search button </TD></TR></TABLE>
reading owns you.
i been searching.
all i could find is a parts list with a very brief description of what to do
reading owns you.
i been searching.
Re: (djsire)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djsire »</TD></TR><TR><TD CLASS="quote">
this basically tell me NOhing!</TD></TR></TABLE>
so search for a complete list, stop being lazy
reading owns you.
i been searching.
all i could find is a parts list with a very brief description of what to do</TD></TR></TABLE>
haha, u aint BEEN searching hard enough, i guess the search owns you i found all the info i needed on the h23 vtec conversion, so i know its there.
he means you will have to swap all of your vtec parts from your H22 motor onto the H23 block, pretty much the only H23 parts you will use are the block, pistons, and crank. i cant remember exactly how the swap is done you have to search for that
reading owns you.
i been searching.
lol basically, just gets me mad that the is an h23vtec faq thread and people are too lazy to search...i did 4 of these i know them pretty good...he's just asking the wrong questions.
plain and simple yes.
need:
h22 head
h22 headgasket
h22 headstuds
h22 lower timing gear
h22 timing belt
h22 header
h22 water pipe
h22 thermostat housing
h22 water pump
i think thats pretty much it...
need:
h22 head
h22 headgasket
h22 headstuds
h22 timing belt
h22 header
h22 water pipe
h22 water pump
Re: (djsire)
since youre being owned by the search here: https://honda-tech.com/zerothread?id=510617
thats all the info you need to make it work, if you need someone to hold your hand while you install it, just lemme know
Re: (djsire)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djsire »</TD></TR><TR><TD CLASS="quote">dont i need to use the h22 pistons?
i heard that using the h23 pistons will bring my compression down
to lik 9.1 or something</TD></TR></TABLE>
yeh compression will drop due to the h22's bigger combustion chamber in the head, but will still be a dope setup, for now atleast.
low13da9
12-03-2007 06:00 PM
