-Searched- Question about vacuum hoses on GSR i.m. and f.p.r.
I'm doing a obd2 GSR swap in my 97 civic. My first question is there is a vacuum hose near the back of my i.m. close to the throttle body, and i've been told to just block it off and it'd be okay. But I was wondering if I could just hook it up to my fuel pressure regulator since the f.p.r. works off of a vacuum source?
If I can't do that then where do I hook-up the f.p.r. to work on my civic?
Re: -Searched- Question about vacuum hoses on GSR i.m. and f.p.r. (hondakevin21)
Somebody's got to be able to answer this......
MiG-21 superfan
fpr vac source is usually right across from the FPR on the manifold. just cap off whatever is not used on your manifold. here's mine, it's not a GSR manifold, but you see what i mean, and i've capped off some stuff too.
Re: -Searched- Question about vacuum hoses on GSR i.m. and f.p.r. (builthatch)
The gsr manifold is different but you basically answered my question. I did have a b16 in my hatch so when i got the gsr in there things got a little confusing. Thanks for the help
akcapr
01-25-2011 02:59 PM
