OBDII or OBDI convression in B18C5 into EK coupe 96 (d16y8) ???
Hello friends !
well im going to do an ITR engine swap into my ek coupe civic 96 (d16y8 engine).
I need your advice in what will be the best OBD situation to go with??
A. I know I can stay OBDII and use the original P72 ECU of engine.
B. Im not shore but I think I can use an OBDI P30 ECU.
What will be the best way 2 go ? what modifications ill need to do in the 2 options ?
Re: (abelcr)
Thanks !!
But which ECU i should be using ?? will it be good enough to the enine without any modifications ?
But which ECU OBDI should i be using (if im going to swap an B18C5/B18C ITR engine) ??
These r my converssion harness options:
1.jdm-in-stock SKUNK2 HARNESS - 128$ (http://cgi.ebay.com/ebaymotors/ws/eB...m=260248823490)
2. raceup harness - 100$ (http://cgi.ebay.com/ebaymotors/ws/eB...m=220242709549)
3. Rywire harness - 95$ (http://rywire.com/store/obd2b-obd1-c...6e410182f6c602)
4. xactdyno harness using custom mold that uses push-to-seat pins -$70(http://cgi.ebay.com/ebaymotors/ws/eB...m=330240859824)
5. streetimports harness using custom mold that uses push-to-seat pins - 50$ (http://cgi.ebay.com/ebaymotors/ws/eB...m=310056751254)
What will u recommend ??
Modified by loverboy at 10:33 AM 6/9/2008
Re: OBDII or OBDI convression in B18C5 into EK coupe 96 (d16y8) ??? (loverboy)
You can use a simple obd2a to obd1 harness with a chipped obd1 vtec ecu mapped for your itr motor.
For more information on what this all is, read over http://www.phearable.net/tech/....html
Kobal
09-15-2006 05:32 PM
