b16 in a 91 civic wagon
I have a b16a in my 91 crx si (awesome car) but because of my bigness and my age I have a hard time getting in and out of the car and have grown tired of it. I did the swap myself but is the only one I have done. My question is I would like to put the b16a on a 91 civic wagon (not 4wd). If not mistaken everything is pretty much the same except im am not sure of the hubs on the wagon. Will I be able to use the ones on the wagon or do I have to swap something to get it to work. Is there a spefic model wagon I should be looking for. I know to stay away from the (what i call) the throttle body injection because it only has 2 injectors. If there is anything else I am missing any help would be appreciated. Thanks in advance
Re: b16 in a 91 civic wagon (monzster)
If you have a 2wd wagon....Yes it is the same as doing a swap in a CRX. The wagon hubs will work with the 90-93 DA axles. This is my wagon and my cousin's. they are both 2wd. The swap was the same as doing a B-Series on any EF.
If anyone's wagon is a 4wd your f'd cause the B-Series motor wont work the D-Series 4wd Tranny...
Hope that helps.
Modified by njcivicwagon1 at 6:00 PM 6/23/2008
Modified by njcivicwagon1 at 7:01 PM 6/23/2008
both are very nice cars. i dont think i could get one to look that nice. thanks for the info. im gona miss my crx but in the long run i think the wagon will be better for me and my family. plus i think a sleeper wagon would be cool. thanks again.
Re: (monzster)
I dont wanna sound rude but why not try and lose weight.
I used to drive a Ef hatch put tons of money into it but
was a little to big for the car so instead of losing the car
I lost the weight . . . F'd up part about a month after my massive weight loss
The car was struck with bad luck, run over by an F150, AND T-Boned
by a 79 Dodge ram charger.
Re: b16 in a 91 civic wagon (njcivicwagon1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by njcivicwagon1 »</TD></TR><TR><TD CLASS="quote">
Hope that helps.
Modified by njcivicwagon1 at 7:01 PM 6/23/2008</TD></TR></TABLE>
That's what zc's are for
Hope that helps.
Re: (bluetintruben)
if your talking about why wouldnt you be able to keep 4wd with a bseries motor, it is because, if im correct, the transfer case and the transmission are one integral unit, and i dont think its possible to mount a b20 setup because the 4wd cr-v uses a seperate transfer case...i think.
Hope that helps.
hey i have a question about the 2 wagons that are sick as hell.. i am about to get a wagon for a full reabuild but i have a couple questions and in will the whole jdm ef9 front end fit except the hood.. and wut corners do you run?? the crx ef or ef sedan??? and is there a place or website to purchase jdm parts for these bad boys?? thanks brandon
[QUOTE=njcivicwagon1;34375219]
Hope that helps.
wat about putting b20 CRV motor in it to keep the 4wd
Hope that helps.
