Does skunk intake mani hurt hood clearence on h2b?
I can get a skunk2 pro series for $100 but i want to be able to close my hood. I have an eg with the evo kit goin in. Running spacers is not even a question as this is my DD and to me i think spacers look retarded. Anyone know if this will make the hood not be able to close? I thought i saw pics where the skunk2 sat way higher then the stocker
Re: Does skunk intake mani hurt hood clearence on h2b? (turboedsupe)
just to let you know the intake will hit esp. if you keep the map sen. on the throttle body so if clearance is what you want forget the intake mani
If you relocate your MAP sensor to another vacuum line then you will be able to close with no spacers. I blocked off the vacuum line on the throttle body. Running the evo kit with evo mounts
