What Altenator belt for H22 SWAP with NO AC/POWERSTEERING
im doing an H22 swap into my EG and im almost done. But i can't find a Altenator belt anywhere. Im not running AC or Power steering.i have gone back and forth to advance and autozone and they dont have what i need. Anyone know which belt to use, where i can get it, or a part number? Please help!
Re: What Altenator belt for H22 SWAP with NO AC/POWERSTEERING (Silvertc)
Easy way to figure out which alt belt you need is take your old one cut it anywhere. Overlap it onto the pulleys the belt will overlap cut the access. Measure the length or take to store with you and that is the belt you need. Just make sure adjustment is near the middle for the alt.
Re: What Altenator belt for H22 SWAP with NO AC/POWERSTEERING (fast+forward)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast+forward »</TD></TR><TR><TD CLASS="quote">6 ribbed alternator belt that is 37" long NAPA usually has them in stock</TD></TR></TABLE>
thank you SIR!
thank you SIR!
Location: Beautiful beaches, skies, and ladies. No worries(.) @ the OBX, NC
37" is probably gonna be to big. I know it was for me, when I tightened it the alt pulley was raming the headlight housing. I went with a 35 3/4" 5 ribbed belt from napa bc they didn't have a 6 rib. I had to force it on and didn't even need the tensioner.
hope this helps
hope this helps
autozone, I just bought one myself...
http://www.autozone.com/R,APP1...l.htm
Re: What Altenator belt for H22 SWAP with NO AC/POWERSTEERING (e46civic)
37.5" was way too big for me. maybe different for you
ozzyman
09-17-2003 07:00 PM
