H22A Tranny Issues
Old May 8, 2008 | 11:27 PM
Calliefornia's Avatar
Default H22A Tranny Issues
I've searched but to no avail.
I have a 1995 Honda Civic Sedan as my daily driver and I have a 1998 Type SH w/ atts H22A4 engine and transmission(M2U4), ECU, etc...
Can I install the H22A4 without the ATTS box and with a Prelude SRV H22A tranmssion and have it run successfully?
Do I need special mounts and/or axles other then the HAsport H22 into EG/DC chasis kit...I need the Non ATTS 97+ rear Tranny bracket, right?
What about axles and half shaft combinations?
If someone has installed a H22A4 Type SH with a non ATTS transmssion into an EG/DC/EK or 1992-96 Prelude please help me... it I'd like to know any information you can offer please and thank you.
I'd like to even know if the H22A4 Type SH can be installed into a 92-96 Prelude using the stock SRV transmission without the ATTS.
I know there are others needing the same information...I read all 100+ pages of the H22 into EG/EK/DC/EF chasis and didn't read one definitive answer on this topic.
Thank you.
Old May 9, 2008 | 06:48 AM
v4lu3s's Avatar
RTFM
you need to fabricate a custom bracket to bolt the non atts halfshaft to the block since the atts block is different.
Old May 9, 2008 | 09:08 AM
Default Re: (v4lu3s)
Thank you!
If I am to install this into a 1992-1996 Prelude the only thing that needs to be done is:
Make a custom bracket for the Intermediate shaft to bolt to and some wiring?
Into a EG/DC:
Custom Intermediate Shaft bracket
H series non ATTS transmission
97+ non ATTS H series rear mount bracket
HAsport Mounts
Prelude inner axles and 88-89 Integra outer axles
H series shift linkage
chipped P28 ECU
re-wiring some things
Is my list accurate?
vbolz
Apr 10, 2011 10:30 AM
Wh0 Iz UNREAL07
Mar 17, 2009 07:49 AM
pkel32
Dec 18, 2008 05:05 AM
WhiteHype08
Jan 2, 2004 08:21 PM
