Mounts for b18b into EK
Timing Belt Mount - EM1 - Part # 11910-P30-000
Top Tranny Mount - D or B - All Same
Front Lower Tranny Torque Mount - B - All B Same
Rear Engine/Tranny Mount - EM1 - Part # 50827-S04-N10
AC Driver Side Torque - CRV - Part # 38930-P7J-000
is this ALL that i need?
ive been told i need more parts for the rear and belt mount.
https://honda-tech.com/zerothread?id=2138616
Re: Mounts for b18b into EK (dafuzzbudd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dafuzzbudd »</TD></TR><TR><TD CLASS="quote">
are the extra parts i need shown here?
am i going to need #3 for the rear mount?</TD></TR></TABLE>
Yes, #3. It's different for Bs and Ds.
everything d series, use a 99-00 si lower trans bracket, 99-00 si rear engine bracket, 97-01 crv ac bracket, 97-01 crv engine post mount or 99-00 si post mount bracket. any b series linkage besides del sol vtec, and 99-00 si axles.
Yes. You also don't have to have Si axles. I have axles from a 97-01 DC in my Civic... no prob. The halfshafts and axles will work interchangeably as long as you get the correct male/female end combination on the half shaft and driver's side axle. As long as you stay 97-01 Integra or 99-00 Si, you'll be fine though.
That's why I said:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blk00EJ8 »</TD></TR><TR><TD CLASS="quote">Yes.</TD></TR></TABLE>
...in reference to:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dafuzzbudd »</TD></TR><TR><TD CLASS="quote">so do i need the 2 si parts for the rear mount?</TD></TR></TABLE>
It's not a medical diagnosis. It's either someone who knows or someone who doesn't. The Si was the only 96-00 Civic chassis that came stock with a B series. All the D rear mounts are different than B rear mounts. I'm saying with certainty that you do need the Si rear chassis mount. The T bracket is the same across later gen Bs so you're flexible there.
...in reference to:
opening this back up...
it seems I also need these:
50825-S04-000 BRACKET, TRANS MTG
38941-PR3-000 BRACKET, IDLER
and an si post mount
(i think this is on the block i bought but Im not familiar with what the mounts look like)
and as discussed here:
50810-ST7-000 Bracket, Rear T
I just ordered the top 3 mounts mentioned.
now I need another $100 for the last 3 parts.
can someone confirm what i'm doing is correct?
Just get all SI mounts to stop your headache. I did my swap using all Si mounts but it seems that the lower driver side mount and the lower passenger side looks alike compared to the DX mounts ( not too sure if they are the same like what I used all SI mounts ). But I know for sure is that the L bracket for and civic is not the same as the B and everyone might know that also. As for the ac bracket you can use the CRV ones and keep your civic compressor. Other than that the whole thing from the B20 was used including the intake manifold, idler, alternator all the other things. I forgot to mention to so peeople wont chew me out this b20 is the JDM one thats why the intake manifold is similar to an LS and not the giraffe looking ones that are so long.
in the picture above......
#7 need from SI,
#E-14-1 need from SI,
#1 need from del sol si or crv,
#10 need from Bseries,
everything else from a Dseries..
#7 need from SI,
****, im almost going to match the price of the ls motor with these mounts
do i need the rubber mount 50810-ST7-000? blk00ej8 says i need it, but if it mounts to the chasis it makes sense it's the same mount. so i just need a new t-bracket?
i've read from multiple people that all rubber mounts are reused- that cancels out 50810-ST7-000.
i've also read that top tranny bracket 50825-S04-000 can be reused from d series. i looked it up and all dx/ex/si is the same part number.
so i guess the original mount list proves to be correct, but i need the idler ($23).
blackeg
05-02-2005 07:50 AM
