1 quick questions to people who knows motor( 96-00 swap)
im doing a swap into my 96EK. Ls Swap.
<U>my question is</U>: do i just need the 99si driver side bracket(the one with 2 studs sticking up) and will be able to use my dseries driver side mount? I have that bracket and the 99si T bracket already and just going to use all my stock dseries mounts there after. i just need to know what driver side mount i need or can use
Im just lookin for a quick answer so i can get my swap in asap. been getting the wrong answers everywhere from noobs, now im asking the H-T PRO's
Re: 1 quick questions to people who knows motor( 96-00 swap) (theslugbug)
Not that this is the right forum for that question but i'll get it over with anyways...
You can use the d-series mount, its the same as an si. The si bracket with the three holes ( one for the mount stud and the other two for the engine bracket) will work. As long as you have the right engine bracket that goes under the timing belt cover, the integra one will not work.
Re: 1 quick questions to people who knows motor( 96-00 swap) (Runnerdown)
but if the engine bracket has 2 holes like mine how are u to use the three hole 99-00 engine bracket
Daniel99
07-12-2018 09:17 PM
daver
09-02-2003 01:23 PM
