How to remove mount bracket studs?
Old Jun 10, 2008 | 09:45 PM
gabebauman's Avatar
Default How to remove mount bracket studs?
I have a 99-00 Civic Si timing belt mount bracket that I'll be using for my B20 swap into my 98 Civic Ex. Thing is...I want to replace the two original studs with new ones that I bought from the dealer. I tried smacking one with a small sledge hammer but it didn't budge. Is this something I need to take to a machine shop to have them press out the studs and press in the new ones? Anybody have any tips on how they got their studs out?
Thanks
Old Jun 10, 2008 | 09:54 PM
2fast4u831's Avatar
I'm really 2slow
Default Re: How to remove mount bracket studs? (gabebauman)
Vice grips don't work?? It worked for my h22 bracket. I'm pretty sure those bolts are threaded but I could be wrong.
Old Jun 10, 2008 | 10:12 PM
88ED8's Avatar
Put the bracket in a table vise and put a vise grips on the stud....... should work, you can always use a pipe on the vise grips for extra leverage
Old Jun 11, 2008 | 04:45 AM
gabebauman's Avatar
Default Re: How to remove mount bracket studs? (88ED8)
Ahhh...so they're threaded into the mount/bracket?
Old Jun 11, 2008 | 06:25 AM
xlasianizelx's Avatar
the stud isnt a press, its a screw
... it has threads so try a vice and twist it out,
i had kinda the same problem, the nut for the motor mount bracket was stuck on so tight that when i tried to unbolt it, the whole stud unbolted
Old Jun 11, 2008 | 06:55 AM
HondamanXxX's Avatar
GO GIANTS!
Default Re: (xlasianizelx)
Just the bottom part of the stud isn't threaded. So here are some options.
1. PB Blaster that **** and try to move with vice grips on the bottom of the stud. Go back and forth as hard as you can and eventually it might crack.
2. Use a torch to heat up the metal and it will make it easier.
3. Take the bracket off and bring to a shop.
4. GL. #1 Did the trick for me when I broke my studs in half.
Old Jun 11, 2008 | 08:41 AM
gabebauman's Avatar
Default Re: (HondamanXxX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondamanXxX &raquo;</TD></TR><TR><TD CLASS="quote">Just the bottom part of the stud isn't threaded. So here are some options.
4. GL. #1 Did the trick for me when I broke my studs in half. </TD></TR></TABLE>
Thanks buddy.
Old Jun 11, 2008 | 02:03 PM
Turbo_y8's Avatar
Default Re: (gabebauman)
go to the hardware store, but two nuts that fine the stud and run them both on there and tighten them together(jam nut) and get on the bottom one and lefty loosey!!
Old Jun 11, 2008 | 02:49 PM
khaosman's Avatar
Default Re: (Turbo_y8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo_y8 &raquo;</TD></TR><TR><TD CLASS="quote">go to the hardware store, but two nuts that fine the stud and run them both on there and tighten them together(jam nut) and get on the bottom one and lefty loosey!!</TD></TR></TABLE>
Yep, exactly what I was going to suggest!
Old Jun 11, 2008 | 05:00 PM
ClubRacer's Avatar
Default Re: (khaosman)
when i did my swap... i didn't replace the studs but i do believe they are threaded on there. vice grip may just do the trick.
pmgriphone
Aug 19, 2015 09:42 AM
flanker
Dec 8, 2014 01:26 AM
sextav6
Jan 11, 2012 07:55 AM
brizjuan
Jul 20, 2004 03:22 PM
EKRacer
Mar 24, 2004 07:02 AM
