EG WITH A GSR SWAP, A/C HOOK -UP
IS IT POSSIBLE TO USE THE GSR COMP WITH THIS SWAP???? THE PROBLEM IM RUNNING INTO IS THE A/C LINE THAT GOES FROM THE COMP TO CONDENSOR. WHICH LINE DO I USE???? I HAVE A SINGLE CAM AND DUAL CAM FROM 99-00 B16 BUT BOTH WONT WORK. THERE HAS TO BE A WAY.
PLEASE HELP CAUSE ITS HOT IN FLORIDA
Mr. Badwrench
Re: EG WITH A GSR SWAP, A/C HOOK -UP (miraclehonda)
with a gsr bracket yes.
if you just want to swap the engine leaving your compressor in there, you need a del sol vtec bracket.
well the problem is that i dont have the orginal comp from that car. i know about the delsol bracket trick but was just wondering what it take to use a gsr comp with gsr bracket.
sauceja
07-31-2006 07:07 PM
Hard2Find
02-19-2002 09:02 PM
