Couple b18b questions.
Hey guys, i have a b18b1 swapped into my 94dx hatch and i was wondering if i could find out what transmission i have? I'm turning about 3000 rpm's in 5th gear going 60mph. I think thats a little much for a stock ls transmission. What is the best fitting header i can run on it? I currently have a dc 4-2-1 and i hate it, plus the flange is in the wring spot for my cat convertor. Last question is, is there any stock drivers torque mount that will bolt up to the frame? Im using a crv ac bracket and it seems like the stud is about 1 inch forwad of the d series mounting location.
Re: Couple b18b questions. (yozsi)
sounds like an ls trans to me. the 4-2-1 header you have may not match up simply because its either for a different year b18 or because the engine in your car not being stock isn;t supposed to match up with the stock exhaust system.
Stopsign32v
08-08-2019 05:44 AM
