Engine Swap Need major help!!!!!
Old May 4, 2008 | 02:56 PM
potpot2x's Avatar
Default Engine Swap Need major help!!!!!
I have a b16a2 that went bad and got a jdm b16 to replace it. What parts do i need for the swap? or can i use some from my b16a2?
Old May 4, 2008 | 04:42 PM
elektronsi's Avatar
Default Re: Engine Swap Need major help!!!!! (potpot2x)
its a direct swap, should drop in in reverse order from pulling out your a2, if you can try to pick up a b16b ecu or even one from an ITR
Old May 4, 2008 | 06:13 PM
potpot2x's Avatar
Default Re: Engine Swap Need major help!!!!! (elektronsi)
i noticed that the map sensor is not on the jdm b16. Can i use the tb of the a2 which has the map sensor and use it on the jdm b16 so I don't have to mess with the map sensor?
I need all the help i can get.
Old May 4, 2008 | 06:15 PM
lilo_goki's Avatar
yes u can use anything from ur a2.
Old May 4, 2008 | 06:21 PM
potpot2x's Avatar
Default Re: (lilo_goki)
i was also told that i have to switch over the cfk to the jdm or i would have CEL. I have no clue where it is.
Old May 4, 2008 | 07:21 PM
elektronsi's Avatar
Default Re: (potpot2x)
have you considered converting to OBDI? OBDI doesn't require a cfk sensor, and if im coreect JDM motor didnt use a CFK sensor, but i could be wrong
Old May 4, 2008 | 07:30 PM
potpot2x's Avatar
Default Re: (elektronsi)
i have but i ran out of funds and i am swapping tom. I am trying to find out all info about the swap so the car will run fine... I hope?
If anytbody got any info about things i need to do it would be greatlyappreciated!!!
I can use any info to make the swapping easy.. I miss my v tec
Old May 5, 2008 | 12:47 PM
potpot2x's Avatar
evrything ran smooth today..... Tom is the day we fire up my beast. Thanks for the help. elektronsi and lilo_goki
jw15u
Nov 14, 2009 06:57 PM
Metalluthier
13
Oct 28, 2006 09:26 AM
Brian Hinson
13
Jun 24, 2006 04:05 PM
birds_sol_94
Sep 29, 2004 01:41 PM
