01 gsr swap in 99 ek
hey guys i am going to buy a 2001 gsr motor with a 2000 honda civic si tranny with the following mods:
gsr motor(b18c1) full swap with 76k on it
OBD2-OBD1 Coversion harness
Skunk 2 Stage 1 cams
Skunk2 adustable cam gears
ENDYN ported Skunk2 intake manifold
JG Edelbrock Type R throttle body
Type R valve cover cut to have acces to cam gears
RC 440cc injectors
AEM fuel rail
AEM adustable fuel pressure regulator
AEM fuel filter and gauge
Walbro 255 intank fuel pump
ENDYN recirculating catch can
hondata 200
my question to every1 is what exactly will i have to get and use to get this swap in my 1999 honda civic ex with a d16y8 currently in it?
1.such as will the b series axels fit in my stock 99 ex hubs?
2. what wiring harness should i use? the 01 gsr harness or the harness from my d16y8? and with whichever one i do use what modifications will i have to do to the harness? keep in mind that the motor is tuned with the hondata 200 ecu
3. what exactly will i need to do to drop this swap in my civic
RC 440cc injectors
AEM fuel rail
hondata 200
Re: 01 gsr swap in 99 ek (blade0314)
1.The axles will fit
2.use your stock ex harness but read the thread about the wiring mod you need to do
3.you need to get the rear T-bracket (rear tranny mount) off an em1, and you need driver side post mount from an em1, and if you want to keep AC then you need the em1 ac mount as well
Re: 01 gsr swap in 99 ek (creepy116)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by creepy116 »</TD></TR><TR><TD CLASS="quote">1.The axles will fit
3.you need to get the rear T-bracket (rear tranny mount) off an em1, and you need driver side post mount from an em1, and if you want to keep AC then you need the em1 ac mount as well</TD></TR></TABLE>
I'm pretty sure the 99 Si A/C mount will not bolt up to the Civic A/C compressor. Perhaps I am wrong, but I know for sure the CRV A/C bracket WILL work as will the P54 bracket found on the B16 DEL SOL's.
caseyknowlson
03-20-2018 08:15 PM
ssmtyper
17
11-21-2011 02:58 PM
