Acceleration Issue
I have just completed a engine swap its a CRVTEC IN A 1990 HONDA CIVIC hatch with 1994 integra wireing harness's for the body and the engine. I have had a few wiring issues that I thought I had overcome. Now though when I am racing the car on a 3/8 mile dirt track I am using alot of throttle and when I go past exactly half throttle the car just drops to idle and will not continue to accelarate, I am thinking either the TPS or the MAP sensor. It has since gotten worse and now will now only accelerate with a tip in a of the throttle maybe 1/4 inch and will go up and down with a kinda like it is running out of fuel, then comes back alive. I will be switching the TPS and MAP SENSORS tomorrow, I just wanted to know if anyone else has delt with a issue like this and what the outcome was.
here is a brief descrip of what I am running, crv block, gsr head, 84.5mm pistons cp, 340cc injectors, inline fuel pump from a 1990 ford 302, it has a fuel pressure reg and I am running about 85 psi for fuel, stock cams, cheap ebay 4-1 header, and cheap ebay gsr intake, bored out throttle body, cometic head gasket arp rod head and main bolts and rods, gsr water pump, acl race bearing's i know i listed alot of crap but just want to see about getting a idea of what could be wrong other than the TPS and MAP
just looking to get some feedback, i hope this is the right forum to post in. Thanks, chad
Modified by enduronut at 7:30 PM 5/12/2008
rolledthatho
Feb 20, 2011 05:58 AM
didder
13
Nov 24, 2008 03:08 PM
nipcup101
May 11, 2008 12:31 AM
