Help Ek b20 swap!!!!!!!!!!!!!!!!!!!!
i was told that for my engine to fit right i need to get a 2000-1999 si drivers side engine bracket like in this pic
the problem is the b20 uses 2 bolts to bolt the bracket not 3 so wut bracket should i use.
Re: Help Ek b20 swap!!!!!!!!!!!!!!!!!!!! (jdm-ek-si)
I am 100% sure it fastens to the block with 3 bolts, not two like you mentioned. Remove the timing cover and look behind it. There are three bolts there, not two.
Re: Help Ek b20 swap!!!!!!!!!!!!!!!!!!!! (Hybrid96EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid96EK »</TD></TR><TR><TD CLASS="quote">I am 100% sure it fastens to the block with 3 bolts, not two like you mentioned. Remove the timing cover and look behind it. There are three bolts there, not two.</TD></TR></TABLE>
Yeah theres deffinately 3 bolts holding it on there
my bad i saw the third hole when switching the mounts. When i olny saw 2 screws i didnt want to start the project without knowing i had the rigth part thnx
MeanGreenEG9
01-10-2003 07:15 PM
