itr lsd in s4c trans
hi ,
im from south africa and the knowledge on hondas over here is pathetic.
i was just wondering what i need to fit an integra type r (dc2 ) lsd into a s4c transmission (from my b16 ek civic).
i know i need the itr final drive , distance collar , 1st counter gear and needle bearing, but is that all ? is the actual casing big enough to hold this diff?
any info would be greatly appreciated
Moderator
Re: (fishy21)
what you have to do to fit an ITR dc2r lsd into an s4c (b16 hydro tranny)
get itr lsd (with 4.4 ring gear)
crack open s4c case
pull out s4c open diff
drop in itr lsd (you may need to shim this) follow a helms for correct clearances
reassemble
install in car
you now have LSD tranny
crack open s4c case
reassemble
install in car
Black R
03-05-2003 08:08 PM
