Engine mount tricks
Old Sep 8, 2003 | 07:57 PM
txhatch's Avatar
Default Engine mount tricks
I am swapping a b18c into my 97 dx and we are having a problem lining up the mounts. Is there any tricks to it? Also to make sure, can i use the dx tranny side mount?
Old Sep 8, 2003 | 11:46 PM
ELESVEE's Avatar
Default Re: Engine mount tricks (txhatch)
bolt the rear mount in first, then use a jack under the tranny to lift the motor up or down and line up the other two mounts. I recently put the polyurethane inserts into my mounts and that was a bitch to line em all up. good luck. PJ
Old Sep 9, 2003 | 01:17 AM
Kamin's Avatar
Default Re: Engine mount tricks (ELESVEE)
YES YES YES rear tranny mount first
its IMPOSSIBLE to get it in, once the other mounts are on.
Old Sep 9, 2003 | 09:23 AM
txhatch's Avatar
Default Re: Engine mount tricks (Kamin)
Ok thanks for the help we will try that.
Old Sep 9, 2003 | 11:38 AM
showtymers619's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by txhatch &raquo;</TD></TR><TR><TD CLASS="quote">I am swapping a b18c into my 97 dx and we are having a problem lining up the mounts. Is there any tricks to it? Also to make sure, can i use the dx tranny side mount?</TD></TR></TABLE>
you have to get an EX or SI driverside engine mount
and SI L bracket
Old Sep 9, 2003 | 11:50 AM
Kamin's Avatar
Default Re: Engine mount tricks (ShowTymers619)
NO
you need B series mounts. integra GSR, civic SI (99-00), del slow vtec
Old Sep 9, 2003 | 12:17 PM
txhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShowTymers619 &raquo;</TD></TR><TR><TD CLASS="quote">
and SI L bracket
I already know that and have them.
CivicUtah
Sep 18, 2007 02:17 PM
transitions
Jun 8, 2005 09:03 PM
97civicdx
Feb 9, 2005 12:32 PM
T--Rex
17
Dec 11, 2004 11:18 PM
BigZ88
11
Apr 8, 2003 07:06 PM
