doing a auto to manual tranny swap on a 00 integra, need help with parts list
im gonna attempt to do convert my man's teg from auto to manual, plz tell me if im missing anything and any probelms i should run into with the swap
tranny, clutch pedal,cluster,ecu,shift linkage,center console,slave cylinder???????anything else?????
1 Post
Re: doing a auto to manual tranny swap on a 00 integra, need help with parts list (AznInvasion)
5-speed pedal assembly
clutch master cyl
hydrolic line going from clust MC to slave cyl.
5-speed tranny
shift linkage
shifter
ecu
clutch master cyl
5-speed tranny
shift linkage
shifter
ecu
I've just done a similar swap into a 97 LS. ( B18C1 / Auto to Manual swap )
Parts needed:
Tranny
Front lower tranny mount
Upper tranny mount **see below**
Shiftlinkage / Shifter
ECU
Manual Brake / Gas pedal assembly **Not necessary, but prefered**
Clutch pedal / clutch master cylinder assembly
Clutch fluid reservoir and mounting bracket
Hardlines / Coupling (mounts to firewall) **92-95 civic lines will work **
Clutch slave cylinder
All necessary brackets and bolts.
Also, you will need to either:
Cut the upper tranny mount bracket off, and weld in a manual bracket.
or
Get an aftermarket upper tranny mount from Place Racing / HCP.
HTH
Parts needed:
Tranny
ECU
or
HTH
