frankenstein k20/k24
Moderator
Re: frankenstein k20/k24 (ek_jeremy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek_jeremy »</TD></TR><TR><TD CLASS="quote">does the rsx head bolt right on to the tsx block like a b16 head bolts onto a b18c block???</TD></TR></TABLE>
yes
yes
Even better, there is only one head bolt size for either K24 or K20.
If you want the water/oil cooler you will need to do some machining on the K24 block. Unless of course you have the TSX block.
brian g
brian g
willard steen
04-05-2016 12:22 AM
