CRV or LS??
I have two options either the CRV or LS motor. I was wondering wich one would run faster in my coupe and wich one is going to run faster stock. Also I'm planning on putting a vtec head next summer so I want to know wich one is going to make more power with vtec
With crv you're going to need to match the vtec head to at least 84mm, which means you'll have to get new sleeves....LS might be the way you want to go.....all depends on how much skrill you wanna drop....
Well for right now i want to keep it stock (no vtec head) but next summer I want to build my motor a bit but thats somthing I did not that you have to resleeve to put a vtec head on a crv. What else do you have to do except the oil line I already know that
Thanks
Thanks
well u don't have to resleeve the head, but if you don't you risk the pistons tearing the head gasket apart with the different bore sizes (81mm vs 84mm).
Other than that, everything else is the same as ls/vtec swap.
Plans for a turbo depend on your budget. I suggest doing a search to find out which would fit your needs.
there head gaskets just for this swap using the b16 head and the b20 block.cometic makes it check race engineering raceeng.com [URL].there are also pistons for this swap on there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abiliTy »</TD></TR><TR><TD CLASS="quote">the b20 will be about 1000 more dollars.. if money is a issue.. go with the b18b</TD></TR></TABLE>and you get this number how?!?!?
$1000 more... WHAT R U TALKING ABOUT??? I have a stock B20 in my 2000 Coupe. If you're going stock (Non-vtec) go with the b20, but only if you can get one for a good price ($800 and less) I ran a 15.6 at the track with chrome 17's and full interior, full tank of gas and a bunch of **** in my trunk. However, now with chip and CAI, I am beating cars that are verified 14.8. 14.9 1/4mile cars...
AH man that is sweet. That's exacly what I was looking for. where did you set you rev limiter and you say you have a chip and CAI and you beat cars that run 14.8 in the 1/4 mile that is what I'm planning on putting in my car thanks for the help man
dfJDM
Jan 17, 2011 02:52 PM
