F20B Oil pan Same as H22?
Re: F20B Oil pan Same as H22? (Magnaflow)
i havent looked at it that close but at first glance they look the same.. if you can wait till next week i can tell you for sure...
im gona assume you have a f20b? is it a 5spd motor? if it is can you measure the throttle body for me? i got a auto motor and im trying to figure out the differences. my tb is about the same size as a f22a or d16y8
Re: F20B Oil pan Same as H22? (JDogg)
i was also wondering why the autos make 20 less hp than the manuals on the F20B setup....i know cams are usually different in these circumstances....add lower end power but lose top end power....i dunno
I can measure mine, but mine is / was an Automatic. I am converting it to a 5 spd. with a manual tranny from a prelude. Do you guys know if I will need a different ECU because of the Auto-Manual conversion?
