easier instructions/diagram to wire VAFC into eg w/ GSR swap??
As everyone knows, the instructions that come with the VAFC are very vague. I tried doing a search, but come up empty handed.
I know i posted a topic like this before under a different name to find out the same thing for a 99 grs'ed EK VAFC wiring diagram. I got lucky and someone knew what i was talking about.
What im looking for is something simple, like,, take the pink wire from the VAFC and connect it to the black/yellow wire of the ECU side wiring. Something simple with color codes. I will know what wires are what when it comes down to the additional wires i have to add, which i think VTEC Solenoid would be the only one youll wire into the VAFC that isnt factory.
i am running a chipped p28 with a skunk2 mani (no stock ******* GSR mani!!) thanks to all that help me out!
-james
-james
Re: easier instructions/diagram to wire VAFC into eg w/ GSR swap?? (SofaKing)
I am in the process of making a more user friendly diagram for V-AFC installations, but here ya go:
V-AFC Installation (OBD1)
The following you SPLICE into the wire (do NOT cut the wire):
V-AFC Power:
- Red wire splice into the A25 pinout (Yel/Blk wire)
- Orange wire splice into the A25 pinout (Yel/Blk wire)
V-AFC Ground:
- Brown wire splice into the D22 (Grn/Wht wire) *make sure you splice this closer than the Black wire
- Black wire splice into the D22 (Grn/Wht wire)
V-AFC RPM Signal: Green wire splice into the (I forgot the wire you splice to at the ECU, I am currently checking back with a friend I installed this into)..
V-AFC Throttle Signal: Gray wire splice to the D11 (Red/Blk wire)
The following you CUT the wire leading to the ECU, wire it from the sensor to the V-AFC, then from the V-AFC to the ECU:
V-AFC VTEC Solenoid hookup:
- Purple wire to the A4 pinout (Grn/Yel wire going to the ECU)
- Pink wire to the VTEC Solenoid (Grn/Yel wire going to the Solenoid)
V-AFC VTEC Oil Pressure hookup:
- Yellow wire to the D6 pinout (Blu/Blk wire going to the ECU)
- White wire to the VTEC Pressure switch (Blu/Blk wire going to the sensor)
For the BLUE wire on the V-AFC, I don`t believe it is used unless you have a Wideband O2. But I could be incorrect.
HTH man.
V-AFC Power:
V-AFC Ground:
HTH man.
Re: easier instructions/diagram to wire VAFC into eg w/ GSR swap?? (poison)
hell yes, thanks. For the RPM signal, i remember the factory color as blue or green, im gonna check my manual right now. hopefully be able to come back and edit it in here. thanks!
EDIT: the manual shows it as a solid blue wire, the wire can be found at the back of the TACH (behind cluster) and at the distributor, i guess the smaller dizzy plug has this blue wire. As to what color it is down at the ECU, i dont know, my freind with his ITR is comming over tonight, im gonna take a peep at his...
Ya, I do know that you can hook it up to the Tach lead which is the Blue wire leading from your distributor to your Gauge cluster, but I remember hooking my friend`s up right by the ECU -- I just can`t remember which pinout it was.
thanks poison, finally wired that sucker in, and it worked. The RPM Signal is a red wire w/ black strip, i forgot what plug/#, i left my diagram in the garage. The only thing that varied from what you posted above is the throttle sensor,, on the wiring by the ecu is pink with a black stripe, not red with black stripe.. at least on my car it was that way,,, wierd. Up on the TPS it is red/blk,,, go figure. anyhow, just sayin thanks and its running great.
-jimbo
-jimbo
chrisir19
09-23-2003 08:42 AM
blue, connect, diagram, diagrams, distributor, distributors, gsr, hook, instructions, pinout, splice, swap, vafc, wire, wiring
