LS/VTEC Swap
Old Sep 10, 2003 | 09:28 AM
Frankenstein's Avatar
Default LS/VTEC Swap
Putting my LS/VTEC into my 96 Hatch I just bought. I did a search but didnt find what I needed. I need to know the proper ecu and Distributor, mounts, axles, linkage etc. etc. etc.
The motor is coming out of my 91 Integra. Also, any help with wiring, install tips etc. will be helpful.... my email is:
evilcleatus@hotmail.com or evilcleatus@comcast.net
Oh... I have B16 Head B18A Block and OBD0 Dist. and ECU
Old Sep 10, 2003 | 01:04 PM
V3locity's Avatar
Default Re: LS/VTEC Swap (Frankenstein)
you can't use your ecu or dizzy. your car is OBD2
Old Sep 10, 2003 | 05:35 PM
VTECVillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frankenstein &raquo;</TD></TR><TR><TD CLASS="quote">Oh... I have B16 Head B18A Block and OBD0 Dist. and ECU</TD></TR></TABLE>
Get rid of those OBD0 parts and get an OBD1 or OBD2 distributor and a chipped P28 or P30 OBD1 ECU with OBD2 to OBD1 jumper harness - that is if you are allowed to convert back to an older OBD in your state.
Don't try using the OBD0 stuff though, it'll give you wiring problems and it's simply just too old.
Most people on here, myself included, don't like to do general homework for people. The rest of the info you need can be easily found here with the search. Just look for anything about B series in a 96-00 Civic and sort through that and I'm sure you'll find what you're looking for.
Kid-jdm-teggy
Apr 26, 2014 02:27 AM
91integra_rubio
Feb 11, 2010 04:38 PM
Iwant2run13s
Sep 21, 2007 06:07 PM
