#Pic request# h22 hybrids with HCP mounts ---- how far to drill hole on passager mount
i bought HCP mounts but no damn instructions,, so i searched here for pix buy no luck
i want to put my motor in today, after waiting for so damn long, but i have no clue how far to drill the hole on the passager mount. any pix and input would be great
Re: #Pic request# h22 hybrids with HCP mounts ---- how far to drill hole on passager mount (H23vtec
does anyone know how many inches apart they are or should i just drilla hole in the middle and a bit lower then the stock one
If I'm not mistaken, the unused 'pilot' holes that are there from the factory (ones closest to the passenger frame rail) are where you are supposed to drill, they just need to be enlarged. I'm not sure which size bit though, someone else want to confirm/clear this up??
The small holes to the right of the original bolt holes are called the "pilot" holes. You enlargen both pilot holes with a 9/16" drill bit so that it'll accomodate a 17mm bolt, and that is your new mounting location for the passenger side mount. You can go to http://www.HCPengineering.com and look up instructions there online. Some minute changes to those instructions (like axles) is different but for the most part it's everything that you'll need right there.
ok i enlarged those two small little holes on the passager and trimed one of them
that was easy but putting my engine in took hours. what a pain in the rear, it was a really tight fit.
thanx for the replies, it was a lot oh help
I drilled mine out with the engine in the car. That was the easiest way it seemed. good luck, and have fun with it.
BOMBCRU
12
06-28-2005 01:09 PM
