Putting a JDM GSR engine into my 94 integra LS: HOW TO???
Ok I have a 94 integra ls. I have the stock b18b motor with simple boltons. If I were to buy a gsr engine swap what would I need to do to make it run like a stock GSR. I know the swap comes with tranny, ecu, axels, exhaust manifold, im, and im pretty sure everything you need. If there were oarts missing could I take them off of my LS and put them on that engine. what problems might I encounter.
Re: Putting a JDM GSR engine into my 94 integra LS: HOW TO??? (integraautox)
should be all plug and play and adding some wires for vtec and knock sensor...
do a search this has been covered hundreds of times...also check out http://www.c-speedracing.com for a good swap article...
