motor mount
Old Sep 9, 2003 | 08:07 PM
Ransom's Avatar
Default motor mount
Ok i have a 89 hatch. I had a b18a1 in the car. I threw a rod threw the block and had to get a new motor. The motor that i got is a b18b. I thought that the B18a and the b18b were pretty much the same as far as the blocks are concerned, but when i got the motor the drivers side mount that is attached to the blocks are different. I have the hasport mounts and the mount will fit the b18a, but wont fit the b18b. What should i do?
Old Sep 10, 2003 | 03:56 AM
h22 ef's Avatar
Default Re: motor mount (LudeSH)
hit yourself with a hammer and then switch the brackets
Old Sep 10, 2003 | 05:08 AM
VTECVillain's Avatar
Change the driver's side mount bracket on the B18B1 with the one from your B18A1 and it'll bolt in with no problem.
Old Sep 10, 2003 | 11:36 AM
Ransom's Avatar
thanks for the help that is what i thought.
shaylude01
Mar 13, 2011 03:55 AM
vdubsduncutit
May 2, 2010 09:07 AM
GSR-EG-92
Oct 23, 2008 06:14 AM
J.nguyen
Aug 23, 2006 05:15 PM
J.nguyen
