Dx harness, LS distributor question
I have a 99 dx swapping in a 2001 ls motor, I'm using the dx harness but when I try and plug the harness up to the distributor it doesn't fit so do cut off the dx plug off the dx distributor and wire it on the b series distributor and plug it to the dx harness?
Anyone have a wire diagram that could help me out with this?
Re: Dx harness, LS distributor question (xvietxkhmerxboix)
but the integra has 9 wires and the dx has 8 where do I put the other wire do I just leave it hanging and tape it up?
I haven't personally dealt with the OBD2B 00-01 Integra parts. I do know that the have an immobilizer built in the ECU which might have something to do with the distributor wiring but I'm not sure. If I had a Helm's for the 00-01 Intregra I would help you out. You might have to switch to the OBD2 96-99 Integra distributor for the wiring to match up. Hopefully someone with a similar setup will see your post and clear that up. Good Luck.
elmalouno
04-11-2009 04:48 PM
cartracin6
11-22-2004 02:07 PM
b20guy
04-06-2003 04:43 PM
