no power or pulse to injectors after b18b swap...HELP
As stated, the car is an obd1 integra w/ a jap spec b18b engine.. We just switched the harness to a usdm harness and have no pulse or power...The car will run off of start. fluid, and all the grounds were checked and cleaned....Any suggestions????Please help me get this thing on the road>>>>
Re: no power or pulse to injectors after b18b swap...HELP (99lspwr)
Have you checked to see what codes you are throwing? If your injectors aren't firing then you're throwing at least one CEL....
Re: no power or pulse to injectors after b18b swap...HELP (VTECVillain)
I am actually posting this for a friend....I will ask to see what codes are present, if any...thanks
Project_EK
07-24-2006 06:42 AM
