Converting auto ECU to manual...
Old Sep 16, 2003 | 10:18 AM
ProJectCvic's Avatar
Default Converting auto ECU to manual...
hey guys i have an ECU in the mail today. I ordered an obd1 MANUAL pp75 and the guy gave me an AUTO p75 instead. the number on there says xxxxx p75 A51
I am pretty sure this is an auto. However i have heard that you can convert the it to manual though. I m just trying to save me and my seller time by convert. Let me know what you guys think. Thank in advance
Old Sep 16, 2003 | 10:19 AM
Default Re: Converting auto ECU to manual... (ProJectCvic)
also, i m throwing a 41 CEL code too... it wasn't doing it when i run the p0a6...UMM???
Old Sep 16, 2003 | 10:28 AM
i m throwing anther code...umm i'll check when i come home from school this eveing
Old Sep 16, 2003 | 10:37 AM
Newman's Avatar
New User
If you chip your ECU, then yes it'll run a 5-spd setup with the correct fuel maps and timing curves. Since a P75 uses a jumper at J1, it'll reroute all of the specs to the chip that you're running. As for the code 41, that's your O2 heater and with yoru P06 or whatever ECU you're running, it may have only looked for a 1-wire O2 sensor where as the P75 looks for a 4-wire O2 sensor.
Old Sep 16, 2003 | 11:21 AM
Default Re: Converting auto ECU to manual... (Newman)
where can i get the chip and can i run the car in the meantime? Or should i switch back to running the gay dx ecu?
Old Sep 16, 2003 | 06:47 PM
anyone?
Old Sep 17, 2003 | 04:25 AM
kenji's Avatar
25 Year Member
I can convert that ECU to manual for you without chipping the ECU.
Also, P06 ECUs use a 4-wire O2 sensor. So, the code 41 problem may lie elsewhere.
Email me at kenji211@tampabay.rr.com
-kenji
Old Sep 17, 2003 | 02:42 PM
Default Re: Converting auto ECU to manual... (kenji)
check your email kenji
imsquisht
Jul 16, 2007 08:19 AM
highrev1987
Jan 17, 2006 06:35 PM
MugenDC4
Jul 25, 2004 10:47 PM
Bleed Black
Feb 13, 2004 10:50 PM
JDMCIV95
Nov 21, 2002 06:30 PM
