A/C MOUNT/BRACKET question
Old Sep 13, 2003 | 03:29 PM
wm5holla's Avatar
Default A/C MOUNT/BRACKET question
how do I keep my AC. my 92 si has A/C . i will swappin a b18a into my hatch. do i need to take off there AC from my sohc vtec motor to use it or do i have to buy a 94+ AC. is the AC on 92-95 civics the same as 94+? will i be able to use the AC mount from a 94+ to kep it or?? what do i need to keep my AC... how much harder is it to install AC after the motor has been installed. thanxs guys
Old Sep 14, 2003 | 05:06 AM
VTECVillain's Avatar
Default Re: A/C MOUNT/BRACKET question (wm5holla)
You need the Del Sol VTEC AC bracket and then simply reuse your stock AC compressor and lines.
db8gsr_teg
Feb 22, 2006 07:25 AM
BlKdOutEk
Aug 12, 2005 09:54 AM
