HELP!!! motor swap into a 88-91 civic hb
ok guys im new to the motor swaps for hondas. im gonna help a co-worker swap in a 94 sohc vtec motor that came out of a 94 civic si and put it into his 88-91 civic dx hb.
my quesion now is what is needed to complete the swap?
i have the whole motor, tranny, linkage, ecu, axles
what else is needed? do i have to change anything on the wireharness or plugs?
please let me know!
thanks in advance!!!!
please let me know!
Re: HELP!!! motor swap into a 88-91 civic hb (drifto808)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">i have the whole motor</TD></TR></TABLE>
Will work is you use the stock DX driver's side mount and rewire to MPFI
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">tranny</TD></TR></TABLE>
Won't work (it's hydro), use the stock tranny (it's cable)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">linkage</TD></TR></TABLE>
Won't work, use the stock linkage
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">ecu</TD></TR></TABLE>
Will work with OBD0 to OBD1 adapter, some under hood rewiring, MPFI wiring, VTEC wiring, 4 wire O2 conversion, etc.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">axles</TD></TR></TABLE>
Will work, stock will also work
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">what else is needed? do i have to change anything on the wireharness or plugs?</TD></TR></TABLE>
You have obviously not done enough research, I suggest searching on here and elsewhere as there are many write-ups and different ways to do this swap.
yah im new to this honda scene just trying to help out my co-worker to get his car running with a new motor. sorry but im mainly a corolla guy whos into drifting but learning how to work on hondas. thanks for your information ill try to research more about it.
any good links or sites you can advise?
drifto808
09-13-2003 01:29 PM
