b20z into eg
b20z into eg
I'm putting a b20z into my eg, is the engine bolt-on? if not, what mods are needed?
how about the wiring? is it plug-in? if not do you guys know where I can fin a diagram,
thanks!
thanks!
Re: b20z into eg (fathergoose)
You'll need to change the driver's side mount bracket and mount to a 94-01 Integra and also get the rear bracket from a 94-01 Integra. Depending on what ECU you are using, there should be little or no wiring.
I hope you have a hydro B series tranny other than the one from the B20Z as it will not work. You will treat this motor like any other B series swap in an EG, comparable mostly to the B18B1.
