what kind of distributor to use with b20??
were puttin a b20 engine into a 5th gen civic, and we need an obd1 distributor to work with it...i thought an obd1 integra ls would work, but it didnt...right now weve got the civic 1.5liter distributor on there (with one bolt), but its kinda running cruddy...does anyone know what distributor i can use (2 plug design).
Re: what kind of distributor to use with b20?? (philafelman)
An Integra LS distributor WILL work, as the B20 head is a PR4 head (LS head). You can use any 92-93 or 94-95 Intergra LS distributor for B20 motor and it'll work just fine. Either that or repin your OBD-2 distributor to OBD-1 plugs.
Re: what kind of distributor to use with b20?? (Newman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newman »</TD></TR><TR><TD CLASS="quote">An Integra LS distributor WILL work, as the B20 head is a PR4 head (LS head). You can use any 92-93 or 94-95 Intergra LS distributor for B20 motor and it'll work just fine. Either that or repin your OBD-2 distributor to OBD-1 plugs.</TD></TR></TABLE>
Yeah either way should work just fine.
Re: what kind of distributor to use with b20?? (VTECVillain)
yeah, thats what i thought too, maybe it wasnt an ls distributor-he got it from a salvage yard....he tried forcing it in with the bolts and cracked his journal, and chipped the cam...and before anyone says anything, i know it only slides in one way, and i checked it both ways...just wasnt workin. the b20 on fit fine, and so did the civic one.
ForceFed Coupe
12-23-2003 08:04 AM
