Idle fluctuation
Old Sep 17, 2003 | 12:19 PM
jmcfkya's Avatar
Default Idle fluctuation
Okay, we had a Jr supercharger on a gsr in a civic hatch. The day before we took the charger off, the idle starting fluctuation between 900 and 2000. Now in the morning, the idle will go to about 4000 for about 10-15 seconds, then drop to maybe 2 or 3 thousand, once the motor is warm it will go to 900 to 2000. We bleed the coolant, changed the idle air control valve, and there is NO check engine codes. Trying to make sense of it. any suggestions?
Old Sep 17, 2003 | 05:30 PM
Turbo(less)DB8's Avatar
Default Re: Idle fluctuation (jmcfkya)
I had this problem (minus the jrsc). I traced the source back to a cracked vacuum hose fitment tube on the intake manifold. The moral of this story is: check all your vacuum lines and listen for a hissing sound (aka vacuum leak).
Also accidentaly switching the map plug with the tps plug can cause this problem as well. Both plugs are the same. Um... yeah I did that one too...
Mike Heath
Feb 21, 2018 02:44 AM
Topdawgg
Sep 2, 2013 05:03 AM
PROJECT 91
Sep 25, 2009 11:18 AM
DA9teg93
May 9, 2005 12:12 PM
ponykillergsr
Dec 20, 2002 06:01 AM
