Can you use a Ls distributor on a vtec motor and stilll hit VTEC
Re: Can you use a Ls distributor on a vtec motor and stilll hit VTEC (DRAG lll INTEGRA)
You can use the LS distributor but you'll have to grind off two of the leg cause it won't clear the vtec solenoid.
Yes but as mentioned you need to modify it to fit. The VTEC function has nothing to do with the distributor itself.
