LS swap into a D16z6 SOHC
Hi, I have a 94' DelSol Si (D16z6 SOHC) I will be swaping an LS into my car in a couple weeks and just wanted to make sure of a couple things before I begin.
I have hondata 3bd on my ECU, hence I can use my D16z6 wireharness and ECU, just dont hook up the vtec plug ?
Will I need to do any modifications to the shift linkage ?
Will I need to extend the exhaust or lengthen ?
I dont know too much about this swap into my delsol such as if I need any kind of other mounts or such, did I miss anything that I might need to know before I begin ?
BTW Im getting a complete LS swap if that helps...
Thanx for the help
Modified by Tommyyy at 9:15 PM 9/16/2003
Thanx for the help
Re: LS swap into a D16z6 SOHC (Tommyyy)
ok. Dont hook up the vtec solenoid or the oil pressure sending switch. Or you can send me your harness and I will send you mine As far as shift linkage goes you have to use del sol vtec shift linkage, i have this for sale as well. What are you going to do with your tranny? want to trade? thanks....
Downey
Northern California (Sales)
04-20-2006 04:31 PM
