93 del sol with a B series swap
I have a 93 del Sol S (d15b7). I am planning on swapping in a B18B, but my only concern is with the AC compressor. Will I be able to bolt my D15B7 compressor right up to the B18b block? If yes, could I just use the same belt?
-ryan
-ryan
Re: 93 del sol with a B series swap (riot)
Well, I put a B16 into an EG, and we used the P30 A/C bracket. The D15Z compressor only bolted up with 2 bolts to this bracket, but it seems to be good enough. A P54 A/C bracket is what you need to mount the compressor correctly, but it's ~$100...
We used a B18C A/C belt because we were using a B18C crank pulley. Just use a Delslo VTEC A/C belt and you'll be fine.
Re: 93 del sol with a B series swap (JDMDA9)
Interesting...but it CAN be done...just need to pick up a different AC bracket? Because I am NOT going to do the swap unless I can keep AC...this is TX...it's REQUIRED.
Re: 93 del sol with a B series swap (SpydiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpydiR »</TD></TR><TR><TD CLASS="quote">it's not required, you're just a pooner. 2 windows down, 90 miles an hour works for me </TD></TR></TABLE>
Sorry, this is my daily driver. My project car doesn't have AC...and never will. I'm not trying to run 11s in my del Sol...I just want to swap a lower mileage motor into it and retain AC. At the same time I don't want another D15b7...I wouldn't mind something that breaks the 100hp barrier.
Again. AC is a MUST for this car.
-ryan
-ryan
Yes, you can keep A/C. But you will need a Del Sol VTEC or JDM Civic SiR B-series A/C mount and belt. The D-series bracket will not bolt up at all...
I was talking about my daily driver. but yeah, A/C is a must in texas, I just learned to deal with sweating buckets since I don't have the cash to fix my ghetto-ness lol
Yeah, I used to go without it in my old cars...I would just never turn it on because I wasn't "as fast"...but then I realized I hated picking up a girl COVERED in sweat...or showing up to work just SOAKING...AC is there for a reason. Gotta use it.
-ryan
-ryan
Ecky
13
02-22-2014 03:15 PM
jayWknight
09-08-2009 10:28 PM
CivicEx95
04-25-2002 01:04 PM
