piston and rod used when putting prelude b20a crank inside of b16 block
i have seen people put these prelude b20a cranks inside of b16 blocks i pretty much have everything i have the b16 motor that i am trying to put a b20a crank inside and i need some info on what piston and rod combination.
Re: piston and rod used when putting prelude b20a crank inside of b16 block (eduardo)
Re: piston and rod used when putting prelude b20a crank inside of b16 block (SkRiBLaH)
he's talkin bout a 95mm crank from an old prelude. Not an ls crank. If he were to do that he would have shitty rod ratio and the motor woldnt last that long.
Re: piston and rod used when putting prelude b20a crank inside of b16 block (ensracer)
A 95mm crank is bad enough in a B18/B20 block. But in a B16A block? OUCH!!! That 1.32:1 rod ratio would likely just punch a hole through your cylinders!
ensracer
04-30-2005 03:31 PM
COLORPROS
16
08-23-2003 07:41 AM
