B and D series distributor compatibility?
Anyone know if the geared shafts inside an OBD 1 or 2 distributor are the same on Civic and Integra distributors?
Thanks
Ben
Thanks
Ben
Re: B and D series distributor compatibility? (Bnjmn)
well it looks like the shaft is different... on sohc dizzy's.
also looks like obd0, 1, 2 are the same as long as you are compring b series to each other
or compring d series to ech other.
taken from ----> https://honda-tech.com/zerothread?id=172026
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mingchi96
»</TD></TR><TR><TD CLASS="quote">no you cannot use a cx distributor on a DOHC engine. any sohc d-series distributor will not work.. it mounts different.. the shaft and the housing is different. </TD></TR></TABLE>poop.
»</TD></TR><TR><TD CLASS="quote">But everything esle on the distributor is the same. </TD></TR></TABLE>
also-> https://honda-tech.com/zerothread?id=542829
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6h8k »</TD></TR><TR><TD CLASS="quote">what year are these...cuase i transfer my ignition coil from my 92 dx to my b16 a and it works fine..</TD></TR></TABLE>
chris_c
12-03-2004 06:44 AM
turbo Si
10-04-2003 07:24 AM
