Swapped out b16 in my 2000 si and put in fully built GSR now some things are acting up.
I pulled out my b16 from my 2000 si and I put in a 2000 gsr block fully built and a b16 head. used same tranny, same speedsensor, same harness etc. When I installed my new motor everything worked fine no checkengine light or nothing, but now my speedometer and odometer dont work. Vtec works, and so does rpm tach. Only thing I did different from other motor was remove the crankshaft fluctuation sensor so the harness for that sensor is just there. Would that be a problem?
I am using a chipped p28 with conversion harness that I was using on my old motor. And I already tried cleaning connection to speed sensor and harness as well. Only thing I did different was take of crank fluctuation sensor that is it. Used my same parts off back of my block and head is same.
Re: Swapped out b16 in my 2000 si and put in fully built GSR now some things are acting up. (mchuang
I have a friend who had the same problem. I'll talk to him and get back to you.
4door93civic
04-11-2007 10:16 PM
skeeterDX
15
11-12-2004 11:47 AM
